North Las Vegas, NV, USA
9/28/2019 9:46pm
Hello, new to the forum & tried finding another thread on this issue, but was unsuccessful. I just got done splitting the case & installing a new crank, bearings,
etc.. My problem is that I believe I somehow Installed the shift drum 180 degrees the other way. I say this because the shift drum pin is on the opposite side of where the manual says it should be. I don’t know if this is possible, but I made sure to double & triple check the placement of the shift forks & drum per pictures in the manual before mating the cases back together. Any insight or information would be greatly appreciated.
Post a reply to: 2002 CR250R Shift drum installation
