Having issues with my front brake it doesn’t work very well at all very spongy ,so far I’ve rebuilt the master cylinder with new seals rebuilt the calliper new front disc as the old one was glazed ,and genuine nissin pads ,it already has a braided brake line.I’ve took these videos
1st one of the pistons one seems to come out a lot easier than the other is this normal ?both push back in to the calliper with ease.
2nd seems to be quite a lot of play in the calliper or is this normal ?
Hopefully these links work.
https://youtube.com/shorts/3ecOIvod9n4?feature=share
https://youtube.com/shorts/lca1iwWRB30?feature=share
start at top. Crack open/close w pressure on lever
After both ends done then crack bleed screw again
should get more pressure.
Post a reply to: 1989 KX 125 front brake issues
