Brooksville, FL, USA
1/27/2012 9:37am
For some weird reason the 3rd time 2 different motors I've had the ball bearings in the governor fly out. They pass over to the left side of the motor and end up in the transmission. Luckily all that's ever happened is the bike either hanging in gear or won't shift up. The bearing finds it's way into the shift drum slot.
I've ordered a new spring thinking the old one is getting soft and allowing this to happen. Anybody else have to deal with this. Here's a pic of the part that the ball bearings are coming out of.
The updated parts from Kawasaki are good.
Other issue is if powervalve itself is hanging up. Has to be spotless and free moving. If it doesn't move freely, or arm is worn the balls will fall out.
Williams is there a mod you can do to the governor I'll mail one up to you?
Post a reply to: KX85 power valve governor problems.
