Uhrichsville, OH, USA
3/13/2014 8:34pm
I recently bought a 2002 RM 250 that runs good but looked to be neglected for a good while. I paid $800 for it as a little winter project. I pretty much replaced or rebuilt the important things such as suspension, bearings, sprockets, chain, bars, levers, and a few other things. The bike ran decent but seemed to run out of fuel or spark when you open the throttle fully. So I figured I would replace the spark plug just to eliminate that as a problem. This is where my issue comes. I bought a NGK BR8EG (this is what my local shop gave me and said the bike called for stock). I got the NGK plug home and immediately realized it was longer then the plug the previous owner had in the bike. I figured the previous owner didn't know what he was doing and put the shorter plug in the bike. I was kind of happy because I figured the shorter plug is why the bike was running like crap. So I put the NGK plug in the bike and slowly turned the engine over and everything seemed fine and the piston did not seem to hit the plug. So I fire the bike up and it barely runs (will idle for a few seconds but immediately stalls). After removing the new longer plug I found that it was smashed shut. So I reinstalled the old "shorter" plug and adjusted the power valve a bit and now the bike runs great. I was immediately mad at the shop for giving me the wrong spark plug but after doing some research online it seems that the RM 250 does call for a BR8EG. I suppose my question would be is this the correct plug if so why would it have gotten smashed shut. Is there a possibility that an aftermarket part such as a high compression head or some kind of domed piston would cause the engine to require a shorter then stock plug. Sorry for the lengthy post and if I sound like a noob (I am new to these big two strokes). Thanks for any info.
Free shipping: VITALMX
I just put in a new top end on my 01 RM 250 ( Same Model as your 02) , Check the top of the Piston for any marks and Yes the NGK BR8EG Plug is correct. Your head has probably been decked for more compression and anyone correct me if I'm wrong...You may need higher octane fuel...check your reeds...air filter..idle screw...Air Screw.
Yes you would need a shorter plug or plug spacer as mentions by everyone else.
http://www.vitalmx.com/forums/Race-Shop,42/1st-Rebuild-RM-250-2001-Rebu…
Post a reply to: 2002 RM 250 Spark Plug Help
