2001 Rm125 carb help
treefitti
Columbus, OH, USA
Edited Date/Time 1/30/2016 5:36pm
How do I remove this throttle cable? Do I take the 2 screws out of the top housing and remove it then?
slipdog
Nor Cal, CA, USA
1/30/2016 5:35pm
Yes, remove the two screws and pull off the top and the slide will come out with it. You can then pull up the return spring and remove the end of the cable from from the slide.
treefitti
Columbus, OH, USA
1/30/2016 5:36pm
slipdog wrote:
Yes, remove the two screws and pull off the top and the slide will come out with it. You can then pull up the return spring...
Thank you! All I needed to know!
Post a reply to: 2001 Rm125 carb help
