Spring, TX
12/27/2020 1:52am
Hello folks, I am restoring a YZ125 and in need of a good useable cylinder that can be used within and up to 4th overbore. Let me know what you have, condition and what you want for it.
Any leads in obtaining one would be appreciated.
Please email me at wfotex@att.net
Thank You!
Thank You!
I just did a cylinder stud write up on the page, as they had issues with pulling studs.
It’s a 1 year cylinder, so getting rare.
Your bike in the pic looks great.
https://www.ebay.com/itm/Yamaha-YZ125-1980-Cylinder-Sleeve-56mm/1843910…
https://www.ebay.com/itm/Yamaha-1980-YZ125-Cylinder-3R3-11311-00-00/154…
However, I pose this information to Mr. "Trickle".....I removed the studs on the my cylinder before I sent it out, 3 were relatively easy to remove, while 2 needed some heat applied to simplify the removal.
What is it that is causing the problems of studs coming loose and why go the effort of retrofitting Suzuki studs?
I mean, they are screwed into the cylinder just like the factory studs.
Why not use "red" loctite thread locker on the original studs to solve the problem?
I've used it on high performance automotive valvetrain studs and never had a problem with those loosening.
I used Suzuki 10mm studs that step down to 8mm. However, you can also use new 8mm studs, and get extra long helicoils or timecerts to fit.
This didn't happen to all G's, but there were a lot back in the day that were stretching studs and pulling threads.
Post a reply to: 1980 Yamaha YZ125......parts wanted
