5/1/2015 10:06am
2008 Ford Fusion with the FSR5 5 speed automatic 205000 miles.
I changed the fluid and filter a few days ago and now have a P0774 code, TCC slippage. If you accelerate normal the transmission will "slide" into second gear, but if you accelerate hard it will shift properly. Prior to the fluid change the converter wasnt always locking up the way it should. I would sometimes have to let off the gas a little and then it would lock. The pan was very clean and had minimal debris on the pan magnet. I used Castol Import ATF fluid that Castrol claims to be suitable to OEM. Upon further looking I see claims that you need to use nothing but the OEM which is Ford XT9QMM5.
Suppose the question is, could the Castrol fluid be causing this issue or is it more likely I have debris in valvle body? Thinking of taking it in and getting it flushed and filled with the OEM fluid. It's my commuter car and really dont want to change transmissions if it can be avoided. Thanks
Mixing the 2 would cause a problem i believe and now you would need to drain the converter.
As for flushing,i wouldn't but that is just me.
Free shipping: VITALMX
He is a tech and read code for which ones ,color coded wires.
Just put 2 on my daughter's focus,got them at napa,40 bucks each.
Post a reply to: Transmission help
