Westland, MI, USA
1/27/2012 4:53pm
I ride a 2004 cr125 and i lost compresion riding one day. I relized it was my top end and that mabie i broke a ring or somthing. I took off the cylinder head and the combustion chamber and piston was dented and chewed like someone started beating it with a screwdriver or somthing. so i think mabie the piston ring broke and got inbetween the cylinder head and the piston and caused havoc. Do you guys think this is right or a tottaly different problem? (im asking beacuse this is my first two stroke and the first time ever doing a top end replacment) thanks
You must have seen it if you took off your top end.
If that's what happened, there are most likely some pieces in your crank case too.
Sorry for your loss.
Your post said you took off the head and combustion chamber...
I thought you were talking about the cylinder.
Get to it!!
Did you check to see if maybe an electrode broke off your spark plug?
That wouldn't cause a loss of compression unless the center electrode broke loose from the insulator, but it's something to look at.
And don't forget to check the electrodes on the plug.
Post a reply to: 2 stroke help
