1/22/2012 9:27pm
Ok guys while I was hurt I decided to Mod out 1 of my bikes. Its an 09 YZ250F. Went from 13:5 to 14:1 Piston, Ported and polished head and stage 2 hot cams few other little things. But, it idles fine and roll on throttle is decent (sometimes pops or back fires). If I go from full close to to full open it just shuts off completely. So I went bigger on pilot, nothing changed went bigger on main nothing changed played with fuel air screw nothing, moved the needle nothing. Am I making it to rich should I try leaner? I dont get it..
Oh also im using 110 octane
thanks
thanks
I didn't spend last night in a Holiday Inn Express but I do know a former Yamaha factory mechanic.
For best results send your Carb to someone who knows what they're doing.
thanks again
The next thing you need to do is change your leak jet. Stock yamahas come with way to rich of lean jet which allows too much fuel to return through the acc. pump diaphram. A smaller jet will restrict the amount of fuel that can re-circulate through the ass. pump diaphram, causing the injection to be a smaller, but sharper and crisper stream. I can't tell you what size leak jet to run, but i've often had to drop down anywhere from 15-30 point sizes. A good start might be around a #40 or so. The other option is to buy an aftermarket cover that has an adjustable leak jet (work very well and easier to re-jet, but not with the money in my opinion if you just have a little bit of time and patience to change jets.)
Also, you would be wise to find someone with a dyno and an exhaust sniffer and pay them for an hour's use to dial your main, pilot, and needle in. Sometimes you can chase your tail trying to jet these mod engines on the track.
From Thumper Talk....
This is an easy job and does wonders for getting rid of the bog that many with an FCR-MX (Only, regular FCR's use the 'Taffy Mod') experience. It can be done with the carb on the bike.
I use a #78 O-Ring (7/16" O.D. X 1/4" I.D. X 3/32" thick) from the plumbing dept. of nearly any home improvement/hardware store. Cost is about $2.00 for a box of ten, share with your pals!
1) Remove the throttle wheel cover from your FCR.
2) Work the O-Ring over the timing adjustment screw.
http://i143.photobucket.com/albums/r155/WilliamLynne1/FCRO-Ring1.jpg
http://i143.photobucket.com/albums/r155/WilliamLynne1/FCRO-Ring2.jpg
3) Pull the O-Ring over the black AP cam thusly.
http://i143.photobucket.com/albums/r155/WilliamLynne1/FCRO-Ring3.jpg
4) Re-install the throttle wheel cover. Just that simple!
Post a reply to: Mod Motor HELP!!
