HOW MUCH Cam 2 Gas!!
sesker15
Upper Marlboro, MD, USA
Edited Date/Time 9/4/2012 11:31am
How much cam2 shouldi put in my kx85, 2003. please help.. thanks
flarider
Daytona Beach, FL, USA
4/14/2008 6:37pm Edited Date/Time 4/16/2016 6:36pm
Huh?
Oh, and noobs suck
sesker15
4/14/2008 7:11pm
Yea the bike is modified, some people are telling me to mix 95 octane and just like a soda can full of cam 2 so i wont burn the piston up. Have you heard of that before? Alos i love the smell of cam2. thanks
flarider
4/14/2008 7:13pm
You use a soda can for measuring?
500 Mike
Kingwood, TX, USA
4/14/2008 7:15pm
I would keep putting gas in it until the tank is full!
crowe176
Spring Lake, MI, USA
4/14/2008 7:15pm
Scott's an idiot, fyi.
flarider
4/14/2008 7:23pm
What size soda can?
ThePipe
Hell WI pop 1, WI, USA
4/14/2008 7:24pm
Make sure you mix the Cam 2 at 32:1 with this.
crowe176
4/14/2008 7:24pm
Monster size.
sesker15
4/14/2008 7:45pm
thanks very much. you where really helpfull.
sesker15
4/14/2008 7:47pm
naw
Slow ~ Pro
Capistrano Beach, CA, USA
4/14/2008 7:55pm
Will a beer can work ?
Racer92
Central, TX, USA
4/15/2008 6:04am
Id throw some mothballs in the tank. Whistling
RNagy052
Bryceville, FL, USA
4/15/2008 6:09am
x2, fill that puppy up.
9/4/2012 8:11am
It all depends on your compression ratio and and if you modifyed the timing, compression ratio eg. 12:1 you need at least 94 octane. this is simple math to figure out the ratio of cam 2 to 87 or 93, you can even use avgas (100LL) 103 octane rating for highway rating, 100 is aviation rating you can get it at your local airport which is $6.6981/ gal i just bought 1.5 gallons yesterday for my car, runs great 3:1.5 (87:103) anyways to figure out how much you need for ex. 3 gal. 93 / 1 gal. Cam2 110... 93 * 3 = 279 + 110 * 1 = 379 / 4 = 94.75 Octane. Multiply both octanes by both gallons of each octane, add together and divide by the total gallons mixed.. or ex. a=110 x=gal. of 110 b=93 y=gal. of 93 c=# to divide by total gal. z=total gal. mixed v=mixed octane... (a * x) + (b * y) = c / z = v (110*1) + (93*3) = 379/4 = 94.75 octane
835
Turbotville, PA, USA
9/4/2012 11:12am Edited Date/Time 9/4/2012 11:13am
As noted above Cam2 is 110 octane. I run 2Gal of Cam2 for every 3gal of 93. So 99.8 Octane with R50. Thanks for the equation by the way.
Oh I run 40:1 too.
TeamGreen
Thru-out, CA, USA
9/4/2012 11:27am
Without attempting to piss on ANY-ONE's Knowledge and to be VERY fair to the Original Poster and his Q:
You don't really get an actual Octane Number WITHOUT having the "mixed" Fuel TESTED.
Period.
The Chemical Constituency of modern fuels is soooooooooo complex that it's the properties of those chemicals and how the react to & with each-other that determines your Fuel's actual "Rating".
&..then there's the Oxygen content which is another animal to deal with.
Sad; but, VERY true.
You can know the "Ratings" if you use your Fuels WITHOUT messing with them; however, a few Fuel Co's DO provide some Rating to Mix ratios that're very helpful.
Good luck.
Btw, it seems that the original intent was to use the Cam 2 as a sort of "Stabilizer" or "Insurance"...also...soda can = 12 ounces.
I'm jus' guessin'...
Signed,
A guy that actually tests fuels at the "Experimental" level.
ns503
NS Toolies, CA
9/4/2012 11:31am
Mr. Brown - dragging up a 4 year old gas thread? Nice first post.
Post a reply to: HOW MUCH Cam 2 Gas!!
