Roselle, IL
6/25/2015 5:16pm
hey guys.............
I had a recent post about my CR125 having problems with "exhaust splooge" dripping onto the swingarm. One of you guys mentioned to "check the crankcase breather hose to make sure it's not plugged".
Well I just started working on the bike to replace the Reed Valves and I came across the Crankcase breather hose. I attached some photos. So I did the obvious. I gave my breather hose a blow job and a suck job (don't laugh). It could not get any air to or from the crankcase, as if the hose is clogged. Is there a check valve in there? Is it supposed to be freely flowing air? It's kind of weird because any air in the crankcase ends up being drawn into the cylinder as the piston moves downward - as all 2-strokes do that. so why is there a breather hose and what function does it serve? I'm definitely not going to split the case and replace the hose - especially during riding season.
HELP.............
HELP.............
if that's the case, when I remove the filler plug on the trans, then I should be able to freely blow air into the trans case.............. I'll be right back........
Thanks Cygnus
It has a little chamber in the upper part of the case that it vents off the transmission.
I drain into a marked cutoff jug,marked st what it takes to refill.
this way when changing the oil you see how much if any is missing.
so,if it always fills it to a certain level then all a sudden not as much comes out you know something changed like a crank seal starting to fail.
milky to me means the water pump sealnis leaking water into the tranny oil by the pump shaft. coolant level full?
it doesnt take a teaspoon of tranny oil to make that mess on thecswingarm,
did the pro thst built it have the cases split apart? that gasket has to lay on a very narrow piece of case and if he missed or screwed it up then a tiny amount of oil would leak thru . Just throwing thst out there. most bikes dont have s gasket there,you put a gasket liguid on the surfaces.
yea - it's kind of gray I guess - dark gray. When I put the oil in it was clear and gold in color. But like I said - the level seems full so it doesn't appear to be leaking into the case.
I'll check the coolant level when I get back home - pretty sure it's good. whenever I've checked the level in the past it's been full.
the "pro" that rebuilt the motor definitely split the case and replaced all bearings, seals, gaskets, rod, piston, etc. Did he screw it up? Possibly. Don't know. All I know at this moment is that it's riding season and I'm not pulling that motor out as long as the bike is good enough to ride - even though it's not running perfect and has "issues". This weekend I will put in a new reed valve, replace the silencer packing, run a hotter plug, use lower flash point 2-stroke oil, and that's about it. If I still have "spooge" and/or low-mid range performance issues - I'll keep working on it - probably jetting stuff.
...warm it up...then go ride it down a straightaway WFO to burn all the oil in the pipe and silencer....
...watch it smoke like BBQ for a while....you just aren't riding it hard enough....
...all you need to do is run it hard before you get on the track and after to keep it running spooge free....
Post a reply to: CR125 CrankCase Breather Tube HELP
