Wytheville, VA
Hi. I recently had a rock hit my inner clutch cover which resulted in oil spilling out. I noticed it when it was still coming out, so I didn’t run it long without oil. At this time it would not shift gears, but it clicks as if it does shift. I took apart the transmission and didn’t notice any damage to any parts. I put it back together with everything to spec per the KTM shop manual. It is still doing the same thing. It clicks, but doesn’t actually shift. I replaced the clutch when putting a new clutch cover on it, but everything else remained the same. Has anyone else had this issue or have any idea of what may cause it? Thanks.
You need to split the cases again, and start measuring parts, looking for signs of excessive heat, warpage, etc. There will be some parts that are fine but a lot will need replacement.
Did you check if it rotated freely before putting cases back together? This will help closer identify the issue.
https://www.ktmpartspro.com/oemparts/a/ktm/59b17f8ceb0bed83303bef59/shi…
Post a reply to: 2018 KTM 150 SX not shifting
