1/24/2022 8:36pm
Hey everyone,
I hope some of you might be interested in my TS185 street tracker. I know its not a mx bike, but it does have a lot of moto parts on it and I wanted it to have a moto influence rather than the usual cafe racer style.
Ive listed all the info on the build below, but there are also full build pics on my instagram - @speaksy_
and a cool feature and article on BikeEXIF detailing the build - https://www.bikeexif.com/custom-suzuki-ts185
Frame:
- KTM 450 head tube welded onto the TS frame to accept KTM triple clamps. Head tube angle steepened approximately 6 degrees.
- Handmade swingarm, 50mm longer than standard, integrated YZ250 axle adjuster blocks. Under slung caliper mount with internally routed brake line.
- New custom subframe with hidden battery mount and fabricated aluminum oil tank.
Suspension:
- KTM 450sx forks, slammed with internal spacers and lowered springs
- Kawasaki Zephyr 750 rear shocks
Wheels and brakes:
- KTM 450 front hub laced to a 19” excel rim, Zeta wave disc, KTM Brembo front caliper and braided line. Custom wheel spacers to eliminate speedo drive.
- YZ250 rear hub laced to a 19” excel rim, YZ rear caliper mounted upside down. Custom wheel spacers, Zeta wave disc, Renthal Sprocket.
- Dunlop K180 flat track tyres, 110/90r19 front and rear
Body and Electrics:
- Number plates and seat pan fabricated from 3mm aluminum.
- 75 Suzuki TM75 fuel tank, pop up filler cap.
- Seat cut and shaped from high-density foam, glued to a 10mm plastic base and covered with a recycled KTM 250sx seat cover.
- Honda CRFx rear fender, chopped and re-shaped
- 12v conversion with Yamaha ttr110 battery
- Micro turn signals front and rear, CRFx LED rear taillight, LED light bar headlight.
- 1992 Suzuki RM125 rear number plate and fender graphics, cut and reshaped to suit.
- Custom tank graphics, designed and made by me.
Engine and exhaust:
- I designed and fabricated cone pipe from scratch, using Pro Circuit shorty internals for the silencer.
- Rebuilt standard bore TS185 engine, mildly ported cylinder.
- Flat slide carb, DNA pod filter
Miscellaneous:
- YZ250 throttle assembly, the TS split throttle cable modified to fit.
- CR high bend Fat Bars, Works Connection billet clutch perch, ODI lock-on grips.
- Yamaha R15 street bike rear sets, foot pegs, gear shifter and brake pedal. Custom adjustable shift linkage.
- Total weight is around 90kg
Build time and cost:
- Around 18 months build time, only working on it when I felt like it.
- Approximate build cost - $3500aud ($2500usd)
- All work completed by myself after hours in my home garage. (Except powder coating)
Cheers,
Cheyne
Frame:
Suspension:
Wheels and brakes:
Body and Electrics:
Engine and exhaust:
Miscellaneous:
Cheers,
Cheyne
Need some action vids!
Any info on the headlight? I built a supermoto and looking to put a plate back on the front with some sort of small LED.
Free shipping: VITALMX
Post a reply to: 2 stroke street tracker build
