ktm exc alignment
Jasondan
Hillside, NJ, USA
Hi there guys !
i need ur advice today please who ever can
i change to a new handle bar and new and new handlebar mounts
im doing same thing like this video :
https://www.youtube.com/watch?v=7qRIxzf9nqA&t=12s
and i even have a glass that i put between the forks to see the glass is stable and not moving
but when i ride i feel like its push me to right or like idk if its the bike or something from the nadle feels like a bit not straight and i visual in my brain to go right
can u guys give me advice? can it come from forks? i run a xplor 6500 cartidge or from the triple clamps ? i installed a new ones but never had any major crash
2/12/2025 7:16pm
Which bar mounts did you put on? Is it possible that one side is in the forward position while the other is in the rear position?
Leo.mason
Los Angeles, CA, USA
2/16/2025 8:45am
Sounds like your alignment might be off somewhere. Since you swapped handlebars and mounts, double check that everything is torqued evenly and that the bars are truly centered. If it still feels off, it could be your triple clamps, sometimes they don’t sit perfectly straight, even if they’re new. Try loosening the pinch bolts on the forks and the axle, give the front end a few compressions, and retorque everything to spec.
Post a reply to: ktm exc alignment
