Engine Bolt leaking - CRF 250 2023
Gold
Liège, BE
Hello guys !
My bike start to have some hours and i notice last time i went riding i saw some oil leaking a bit from the top engine bolt (see the picture).
Should i just unscew it and replace the copper ring, isn't that a bolt to drain excess oil ? If it is why is it leaking even if did not put not too much oil.
engineboltleaking
Factor E
So Cal, CA, USA
4/22/2025 8:20am
Those have sealing washers   Pull it out and replace or try to tighten
4/22/2025 8:50am
That's an access bolt for the rocker arm shafts. Strange that it is leaking but you can just take it out and put a new sealing washer on.
Nairb#70
Ivoryton, CT, USA
4/22/2025 9:01am
No oil up that high except when running.
Gold
Liège, BE
4/23/2025 2:01am
I'll replace it then, do you guys know the torque on this bolt ?
Post a reply to: Engine Bolt leaking - CRF 250 2023
