Bango , NSW
Hey was wondering if you can run dot 5.1 brake fluid in it the manual states to use hydraulic oil only but I’ve read some things and wondering if I have to use hydraulic oil or can use dot 5.1
Mineral oil
Hydraulic oil in a KTM clutch? Hmm, doesn't sound right.
The recommended fluid will be written on the master cylinder cap. If it's mineral and you run dot 5.1 brake fluid in it, likely you'll run into issues with the rubber and gaskets in the system. I think you'll have trouble with leaks, but others might have tried it?
You might try a search for 'mineral oil brake alternative' ... you'll get some results.
Likely you'll be able to find mineral oil at a bicycle shop.
Don’t run brake fluid, it’s supposed to take mineral oil. I’ve used 5wt fork oil in my 05 200exc and klx110 with a magura clutch. No problems.
That era KTM used mineral oil...lots of options including plain old mineral oil available at pharmacy. Better fluids though...like Rickyisms fork oil(5wt or lighter), shock fluid, ATF and so on. No real need to buy expensive mineral oil that may be a trek to find(maybe not).
Free shipping: VITALMX
The bike has a aftermarket cap that’s why I’m trying to work out what it takes that’s what is in the manual but wasn’t certain as have heard conflicting information
The older bikes don’t use brake fluid.
As others have said, just use a light oil like fork fluid.
Post a reply to: 2004 ktm 450exc hydraulic clutch
