2001 cr125 ignition questions
eddie88
Orlando, FL, USA
Bought a 2001 cr125 in a box to build for racing pre-mod H/S.
have no spark.
parts that came with the bike as fast as ignition were all messed up. It had a 2002 flywheel, eBay 2 plug cdi, eBay coil, eBay stator.
i got a 2001 oem cdi and coil.
still no spark.
stator test ok but cant check peak voltage values.
Is the 2002 flywheel compatible with 2001 ignition?
trying to decide if I should just get both or stator first.
Factor E
So Cal, CA, USA
10/30/2023 8:26pm
Check for specific gap measurement between pick up an flywheel
eddie88
Orlando, FL, USA
10/31/2023 3:04am
Air gap is set to .015. All grounds cleaned, tried different coil
Factor E
So Cal, CA, USA
10/31/2023 6:45am
Bad CDI
eddie88
Orlando, FL, USA
10/31/2023 8:30am
Cdi came from a running bike.
my biggest question would be this flywheel.
2000-2001 had an 8 pole stator and in 2002 it went to a 4 pole stator. I just need a firm answer on the 2002 flywheel working in a 2001 system. Emailed rickystator earlier this
kirmkmg and the reply just now was they didn’t think the 2002 flywheel would work in the 2001 system. I guess I will buy a flywheel first. 🤷🏻‍♂️
Post a reply to: 2001 cr125 ignition questions
