Pro SX/MX Race Bike, Motor, Engine program
Edited Date/Time 4/6/2015 10:28am
FOR SALE some equipment Jake Baumert #91 raced in 2014 East Coast Sx and half of the outdoors.
2014 Supercross Motor
2014 MX National Bike
The Supercross Motor Engine Builder
Chad Wells with Commonwealth Motorcycles is based out of Louisville, Ky. Chad has a long history of building bad ass road race motors for myself and a list of other pro Road Racers and custom projects. His list of qualifications are endless and his precision/attention to detail and craftsmanship backed with his Mechanical engineering degree make him my top choice for engine design, planning, maintenance and performance.
Here is one of his bad ass projects:
*First person to custom build a turbo for a Ducati Diavel
https://www.youtube.com/watch?v=TMDD8wXoBIo
http://www.autoevolution.com/news/236-hp-turbo-ducati-diavel-anyone-52256.html
Forum praises:
http://www.mvagusta.net/forum/archive/index.php?t-58218.html
http://www.vfrdiscussion.com/forum/index.php/topic/73798-dynojet-pcv-au…
2014 SUPERCROSS MOTOR
Bought new in November 2013
6.45 Hours on engine. We do top ends at 15 hours, Bottom end at 30 hours.
Vortex ECU Fully custom Dyno tuning fully mapped at 5% throttle intervals for smooth accurate power and reliability. Mapped for VP MR PRO6- Dyno screen shot attached. [5.65 hp gain over stock and 1.79 torque gain over stock.]
Throttle Body modded to match ECU Map
Motor Modifications
Lightened and Balanced Crank by Crankworkz in Arizona
Crank and rod has oil shed coating
Lightened flywheel
Carillo Long Rod SMALL WRIST PIN
CP Platinum Piston
Ported, polished, and milled head
Custom Web Intake and Exhaust Cams designed by Chad Wells
Hinson Billet Race Clutch & Cover
Pro Circuit Water Pump cover
Pro Circuit Water Pump impeller
Pro Circuit Billet Ignition Cover
Yosh Ignition Cover plugs - red
Undercut Transmission
Transmission coating (REM POLISHED AND SUPER-BLUED) along with oil pump
2012 OEM 2nd Gear set installed
Complete Worldwide ceramic bearing kit in motor, MAINS, TRANS, CAM, H20 PUMP,ETC...
Option 1 – $7,000 Stand alone purchase including the ECU and Throttle Body. As you know the Vortex ECU is $1,000, and TB Around $350 w mod.
Option 2 – $5,500 Purchase Option 1 items, and send me your stock “running” motor so I can put the chassis back together.
*Chad Well's can also set up a maintenance plan if you wish to give you a reliable engine program and or build more motors.
2014 OUTDOOR NATIONAL RACE BIKE
Bike was bought new in January of 2014. 2013 Vin
16.4 Total Hours on chassis - 5.4 on Engine
Chad Wells Re-built and re-tuned motor with C4MX Frenchy Mods
Vortex ECU Fully custom Dyno tuning by Chad Wells fully mapped for VP MR PRO6.
MOTOR MODIFICATIONS
PC Piston
C4MX Ported, polished, and milled head
Custom Webb intake Cam
Pro Circuit Exhaust Cam
BIKE MODS
DID STX Rims
Talon Hubs
Galfer Tsunami O/S Front rotor
Galfer Rear rotor
Dunlop Tires
TM Designs chain guide kit
TM Designs rear caliper guard
DID Gold Chain
Renthal sprockets
Graeme Brough Suspension
Works Connection skid plate
Works Connection radiator braces
Works Connection start device
Works Connection elite clutch
Works Connection hour meter
ARC front brake Lever
Factory Effex radiator hoses
Factory Effex graphics
Cycra all black plastics
Motoseat ribbed gripper seat
Yoshimura Ti-Carbon exhaust
$12,000 - Will reduce to $11,000 if you don't want Dubya wheels and take stock in exchange.
Email me with questions.
Thanks.
Brandon
bp @ RiderSurance.com
Bike and parts are located in Kentucky.
I can ship to anywhere in the lower 48 states. Buyer is responsible for cost.
Post a reply to: Pro SX/MX Race Bike, Motor, Engine program
