PL
Hey, at the beginning I would like to apologize for my English, notwithstanding i hope that it will be possible to solve the problem.
My motocycle is Yamaha WR 250f 2017.
I have problem with engine code (43) Fuel system voltage: incorrect voltage supplied to the fuel in-jector and fuel pump.
I followed step by step with official service manual; i checked all fuses, relays and wire harness (short/open circuit) all of them is CORRECT, but error code 43 is still flashing.
Starter Relay is also fine.
The tip is, that main relay is all time working (it should not be like that), relay is all time warm and discharges the battery.
The next tip is, that the error code appeared the day after thorough cleaning.
I cleaned all plugs and corroded elements but is still the same... code 43.
I have no idea what is wrong.
Any ideas? Thanks Adam.
If not, then you will need to clean all electrical connections and use Dielectric grease on them.
Also check the batter load voltage as the battery may be bad.
Free shipping: VITALMX
How did you fix the ecu problem?
Did you have to buy a new one, or were you able to fix it?
Thanks... and sorry for the bad english!!!
Unfortunately, I had to buy a new ECU.
Здравствуйте! У вас ошибка 43 !![]()
у вас проблема с Реле! Замените реле и проблема уйдет. Реле находиться рядом с Аккумулятором. Найти его непросто, после того как насос перестает качать, через некоторое время вы услышите щелчок! Это именно это реле 🤝
Post a reply to: WR 250 f error code 43
