Thread size/pitch steering nut?
RF219
Edited Date/Time 5/9/2017 11:04am
Does anyone know the thread size and pitch on the top steering stem nut on a 2016 kx 450
Acidreamer
Mansfield, OH, USA
5/9/2017 7:42am
Take some calipers and measure the outside diameter of the male threads. That will get you started. Then youll only have to figure out the pitch. Hardware stores usually have things on the walls you can use to find the thread size
5/9/2017 10:51am
Acidreamer wrote:
Take some calipers and measure the outside diameter of the male threads. That will get you started. Then youll only have to figure out the pitch...
You can measure pitch with the calipers (but with being a nut, might be tricky.. a metric tape measure or something similar that you can fit inside the nut may be better)
Pitch will be the distance in mm from one thread to the next thread "on center" so to speak. Make sure you're being accurate, as pitches can vary by as little as 0.25mm. But usually it's 0.5mm increments. ie, 1.0, 1.5, 2.0
Paw Paw 271
Benton, LA, USA
5/9/2017 11:03am
They make thread gauges for this that are cheep and very accurate. You may also be able to call your dealers parts dept. and get that info.
5/9/2017 11:04am
Brain fart. You can use the calipers to measure the distance on the threads on your stem too, as they'll match the nut (obviously). Easier than measuring the threads in the nut.
As mentioned by Aciddreamer, just put the calipers on the stem and that will be the thread size. For example, 14mm = M14. Say your thread pitch turns out to be 1.5... then your nut is a M14x1.5.
I know Kawi's parts description just called it a 24mm nut - which is obviously the outside hex size
paddyB745
novato, CA, USA
5/9/2017 12:53pm
Brain fart. You can use the calipers to measure the distance on the threads on your stem too, as they'll match the nut (obviously). Easier than...
It's a 32mm OD. 24 would be the ID.
5/9/2017 1:08pm
Yea total brain fart there.... so it's a M24x?
I think we've given the OP more than enough info to get the answer he's looking for at least
Acidreamer
Mansfield, OH, USA
5/9/2017 2:26pm
M24x3 would be a normal thread. I doubt they use a fine thread for that nut.
Post a reply to: Thread size/pitch steering nut?
