Vital MX fantasy is free to play, but Premium users receive great benefits. Premium benefits include:
- Pick trends
- Create a private league
- And more!
Only $10 for all 2026 SX, MX, and SMX series.
And yes, your bike should have a 520 chain, if it is not an older 125. You did not state year or make of your bike.
Your old chain should have markings on the link that states what size it is for sure.
The RK Chain spec sheet is for consumers to have more information regarding the series of chain they are going to use for their motorcycle. This allows for riders to pick which product to use based on the chain specs. The engine displacement rating for each chain is listed because our RK Chains are used on a variety of applications. Each chain companies will have their own specs based off their chain machines.
To help answer your question, first you need to know what pitch size is on your motorcycle. Your 2014 KTM 125 EXC stock OE chain pitch size is a 520. Depending on what type of riding you are doing, you can choose from a Sealed or Non-sealed chain. Make sure the chain is rated for your motorcycle! If you are replacing the chain for the first time, I would recommend replacing the front and rear sprockets at the same time. This allows for the new chain and sprockets to wear evenly together. Putting a new chain on old used sprockets will cause the chain to wear out at an excessive rate and could cause chain failure.
If you would like any more help, do not hesitate to email us.
Cole Anderson
Racer Support Supervisor
RK Excel America Inc
2645 Vista Pacific Drive Oceanside, CA 92056
Tel: (760)732-3161 Fax: (760)732-3186
www.RKExcelAmerica.com
Post a reply to: RK Chains for 125
