Spring, TX, USA
Does anyone have the instructions for the 105 kit they could post up? I just acquired a used kit but don't have the instructions for it. I have no idea where to start with on jetting, nor do I have part numbers for gaskets and orings.
Thanks
Thanks
For 18+ the base gaskets are the same I think the heads might be also. I know the outer is pretty sure inner is also. I don't remember ordering any different part numbers but bikes run together anymore
I might have jetting specs somewhere also. jetting was pretty close to the 85 other than needle/main.
It's a great kit you will love it..
The jetting specs I could really use and haven't had any luck finding them online so far.
Also, aren't you supposed to remove the spring behind the adjuster for the power valve?
Thanks
https://ktmpowershop.de/mediafiles/PDF/DOK/PP/BED/dok_pp_bed_4764990504…
I think we were running -
142 main
NRKC Needle 3rd clip
45 pilot
Problem is I just have Husky written in notes so not 100% sure that was 105 but that's the 105 needle so assuming.
Post a reply to: KTM 105 instructions?
