So I'm trying to set up my suspension. Got a stiffer spring in at the moment. I have 40mm static sag, but how would a softer spring lower the number? Surely it would be the other way round. I don't understand the mechanicals of this after a lot of thinking I thought I'll come to vital! Is it that the stiffer spring is shorter and requires less pre load? Fried my brain this has.
Cheers
Cheers
Thanks
So you don't want too much preload, but don't want it topped out either? My thinking was more preload, equals less travel right? And also eliminating the softer first part of the stroke on small chop etc?
No, preload has 0 effect on travel. A spring that is too firm will restrict travel however.
From my experience I would highly recommend you try a softer spring, I did and I really liked the results. For £80 it is a very cost effective modification. Worst case you don't like it and sell the spring on ebay for not loads less than what you paid.
So like they said, softer springs will require more preload which forces the shock to extend more. The correct spring will put the shock length in the correct range.
Post a reply to: Explain how a spring rate changes static sag
