Bakersfield, CA
Hey everyone I'm having issues with my son's 2005 yz85 fouling plugs/bogging. We have had the bike for 2 years with no issues until we went to a race and he completely submerged the bike in water. We flipped it drained it, ran multiple cycles of new oil through it until the milky oil stopped coming out of the trans. Since then it keeps fouling spark plugs (6) after about 4 hours of ride time (plug is black and wet). There was also a new low end bog when taking off. I've tried adjusting the air screw and have dropped the needle down one clip (it's now in the first clip position). The bog is also very apparent when you blip the throttle 3/4 to full throttle. Things I've done since the submerge is:
1. Tested compression that was low and replaced with pro-x piston and ring.
2. Replaced oem reed valves.
3. Brand New air filter.
4. Removed pro circuit 296 forest muffler re-packed and cleaned.
I'm starting to think it's a stator or air leak issue. I can't however seem to find stator information for the yz85.
Any ideas or help would be much appreciated!
Did you go through the carb afterwards? May have sucked some grit in.
As for the cylinder, it's definitely worn but the shop I took it to said I should be fine for one or two more rebuilds. I'll probably do a compression test also. I've seen many different posts on what the compression should be ranging from 120-180.
It sounds like crank seals are pretty easy, just confirming you don't have to split the cases to replace them? I planned on doing a full rebuild after this piston but if I'm already taking everything apart I'll probably just do it now.
Thanks for all the replies!
Removal of the flywheel on the shifter side, and the entire clutch on the brake side will be needed, but no splitting of the cases are needed on the YZ85.
Post a reply to: 2005 yz85 issues
