16 kx450f kicks back when kicking over
It kicks back and then it broke the kicker gear. Ecu map? TPS setting? What do you think? Runs great once it’s running.
Thanks
Benton, LA, USA
9/20/2020 4:23pm
With no bike history offered... Here are some items to check.
1. How old is the topend?
2. Valve status, age etc.?
3. Cam chain age? When last replaced?
4. Fuel pump last replaced?
9/20/2020 4:47pm
I just did the top end, timing chain, set valve clearance, all have about an hr on it.
Idk exact hrs on fuel pump.
Runs great when running just kicks back sometimes when kicking it over
Factor E
So Cal, CA, USA
9/20/2020 5:03pm
Decompression mechanism on cam might not be working properly
9/20/2020 5:25pm
I bought a new cam and decompression set up a month ago as the old one want working correctly so it should be good.
Benton, LA, USA
9/20/2020 7:01pm Edited Date/Time 9/20/2020 7:06pm
X2 plus intake valve clearance is set too tight.
Also you stated in your other post that you have replaced your flywheel and stator, so the timing may now also be off.
All the story pieces are not out on this yet.
9/21/2020 6:07am Edited Date/Time 9/21/2020 6:09am
I got up early before work and checked the valves. Intakes are .005,
exhaust are a loose .007 and a reg. 008
Forgot to check the decompression this am
Cam timing spot on.
Stator is bolted in place no adjustment, can’t advance or retard.
I’m going to look up tps adjustment and look into mapping. I feel like it’s too advanced for some reason
Post a reply to: 16 kx450f kicks back when kicking over
