6/16/2015 7:11pm
I picked up this 2001 cr250 not to long ago. It has ran great and has lots of power. Until recently. I got on it today, rode it around slow until it warmed up. Then got on the throttle a little bit. It didn't seem as powerful as before. Then it started to make this terrible rattle so I shut the bike off. When I tried to start it, it took multiple kicks and gas to get it going. (Starts first kick normally) and it doesn't sound the same. It's not as healthy sounding. I have a video of what it sounds like but don't know how to share it.
this is my first 250 2 stroke.
Sounds like it could be excess wear on the piston and rings.
A piston breaking is a sign of either excess wear on the piston ( did not change it as often and required) or worn cylinder creating excess piston slap.
Measure the cylinder and see if it's with in spec's. If not then it will need replating.
You will also need a service manual and a few tools , like a case splitter and a flywheel puller made for your bike specifically.
Expect to put in all new bearings and seals.
This is the piston and beside it is a little piece of it I found. I can see a small piece in the crank but there is obviously more missing. I can't find it in the bottom end and the cylinder/head look good. Is it possible that it blew out through the exhaust pipe?
Free shipping: VITALMX
Post a reply to: 2001 cr250 piston problems?
