Brooklyn, IA
10/30/2020 1:22pm
I just fully rebuilt my 2001 yz125 and when I started it up and rode it, it had a slight bog through mid gear 2nd-4th . Today I did some tinkering with the carb trying to fix the bogging got and started riding . It shifts fine 1st to 2nd but half way through second when I throttle it starts to jerk violently back and fourth and starts to loose power . If I stay on the throttle it will power through and keep riding . PLEASE HELP!!!
That being said, I saw pretty much these exact same symptoms when my buddy put his piston in backwards in his YZ125. Bottom line, the fact that it started after rebuild points to something you did wrong in the rebuild.
Also the float level in your carb. Also that the float valve is working.
Also that none of your jets are clogged.
Also that your needle clip is in the position you think it is in.
Set your air screw to the stock setting.
Post a reply to: Need Help! YZ125 jerking back and forth and stuttering mid second gear!
