Cleaning Engine Cases
Edited Date/Time 11/19/2014 7:36am
Usually i just use some brake cleaner and a scotch brite and or SOS pad but the cases im cleaning are super dirty and that way will take way to long.
Is there any quicker way that does not invlove soda blasting or bead blasting? i have some ultra brite aluminum cleaner on the way for cleaning welding surfaces will that help? i had an idea to soak the cases in viniger overnight (if anyone has done the coins in vinigar thing you will know what i mean) but would that damage cases?
Any input is helpful thanks
O___o
11/18/2014 6:46am
the aluminum alloy that cases are made out of does not react favorably to acid. (although the jug and head do) I believe it has a high tin content which produces a black byproduct during the reaction.
the best solution, I believe, (if you don't want to media blast them) is to soak them in a somewhat pH neutral degreaser, then use a brass bristle brush. Either by hand or on a rotary tool. Exhibit A:
Ardfarkl
San Antonio, TX, USA
11/18/2014 6:50am
Nice!
YZ125H1
Elizabethtown, PA, USA
11/18/2014 7:20am
I used a degreaser not a powerful one on my YZ125 motor. Using a toothbrush just was not enough for me there is still dirt imbedded in the metal. Either try an SOS/scotch bright pad or the brass brush. I used a brass brush to clean the aluminum frame on my 250f it left some black stuff but it washed right off with water. Could try using WD40 with the SOS pad also.
zippy895
Daytona Beach, FL, USA
11/18/2014 8:52am
follow chad watts facebook page to see some kick ass engine porn!
zippy895
11/18/2014 8:53am Edited Date/Time 11/18/2014 9:01am
chad watts.....one of many
zippy895
11/18/2014 9:01am
Vet57
BRO Town, MA, USA
11/19/2014 4:40am
zippy895 wrote:
[img]https://p.vitalmx.com/photos/forums/2014/11/18/70918/s1200_10397976_705961779463863_578804924676914028_n.jpg[/img] [img]https://p.vitalmx.com/photos/forums/2014/11/18/70919/s1200_10255800_675116219215086_5194238137805318002_n.jpg[/img] [img]https://p.vitalmx.com/photos/forums/2014/11/18/70920/s1200_5505_652315834828458_1857029879_n.jpg[/img] [img]https://p.vitalmx.com/photos/forums/2014/11/18/70921/s1200_382509_531337190259657_1974407981_n.jpg[/img] [img]https://p.vitalmx.com/photos/forums/2014/11/18/70922/s1200_375991_242556575804388_1954170115_n.jpg[/img]
Any info on the engine repair stand?
stillwelding
Santa Clarita, CA, USA
11/19/2014 6:26am
Tokyo Mods engine stand. Can be had as a "Bench Only" model.
11/19/2014 7:16am
I know chad well.
Post a reply to: Cleaning Engine Cases
