Shop Clean Out - All Makes Parts
Edited Date/Time 11/14/2017 3:20pm
Honda
• New CR80 (85-02) CR85 (05-07) CRF150 (07-17) OEM Rear Sprocket 49T #41201-GBF-830 - $20
• New CR (99-07) CRF (02-15) OEM Front Brake MC Rebuild Kit #45530-KCE-671 - $34
• New CR125 CR250 (00-04) CRF450R (02-04) OEM Rear Brake Pivot Bolt #46513-KZ4-J20 - $10
• CR125-CRF450R (00-13) Talon Front Hub Black - $150
• CR (97-07) CRF (02-07) RG3 24mm Offset Top Triple Clamp w/ Bar Mounts - $200
• CR (00-03) CRF450R (02-03) Stock Top Triple Clamp w/ Bar Mounts- $45
• CR125 (01) CR250 (02-07) CRF250 (04-05) CRF450 (02-05) Stock Complete Front Wheel - $75
• New CR (02-07) CRF250R (04-09) CRF450R (02-08) OEM Rear Brake MC Rebuild Kit #43520-KZ4-J42 - $30
• CR125 CR250 (02-07) Stock Fuel Tank - $80
• New CRF250R (04-06) CRF450R (02-06) OEM Throttle Cable Boot Cover #17913-KB7-000 - $9
• New CRF250R (04-07) OEM Hot Start Cable - $20
• CRF250R CR250 CRF450R (04-07) Stock 24mm Offset Bottom Triple Clamp - $25
• CRF250R (2006) Owner’s Competition Handbook - $17
• CRF250R (04-09) Falicon Knife Rod Crank Assembly - $100
• CRF250R (09) ICF Complete Polished Transmission - $300
• CRF250R (04-09) ICF Engine Balancer and Oil Pump - $100
• CRF250R (04-09) Fly Wheel - $60
• CRF250R (04-09) Kick Start Gear Mechanism - $50
• CRF250R CRF450R (09-13) Stock Top Triple Clamp - $40
• CRF250 (10-14) CRF450 (09-12) Fork Springs .38kg - $40
• CRF250R CRF450R (06-16) OEM Front Wheel Spoke and Nipple Set - $55
• CRF250R CRF450R (11-16) Stock Front Hub - $70
• CR (92-07) ASV C6 Clutch Lever and Perch Blue - $80
• CR250 (02-04) Cylinder Head - $50
• CR250 (02-07) Transmission Gears and Shafts - $110
• CR250 (02-07) Shift Forks, Drum, Shaft, and Shifting Mechanism - $50
• CR250 (03) Stock Reeds and Carb Boot - $40
• CR250 (02-07) Kick Start Gear Assy & Idle Gear - $30
• CR250 (97-07) Water Pump Propeller & Shaft With New Bearing - $50
• CR250 (02-07) Water Pump Cover - $15
• New CRF450R (02-08) OEM Water Pump Shaft #19241-MEB-670 - $35
• New CRF450R (02-16) 4x OEM Intake Cam Bucket Valve Lifter Caps #14731-MEB-670 - $28 ea
• New CRF450R (09-16) Left Motor Guard #50360-MEN-A30 - $9
Kawasaki
• KX80 KX100 (98-00) Stock Expansion Chamber, Raw Finish - $80
• KX (03-07) KX250F (04-08) KX450F (06-08) Stock Front Fender - $20
• KX KX250F (04-05) Stock Lower Triple Clamp - $30
• KX125 (03) Micro-K Parts Catalog - $15
• KX125 (03-04) Stock Ignition Cover - $17
• KX125 (03-05) KX250F (05-08) KX250 (03-07) KX450F (06-08) UFO Flo Front # Plate - $15
• New KX125 (03-05) KX250 (03-07) UFO Black Rear Fender - $30
• KX125 KX250 (03-05) KX250F (04-05) OEM Rear Brake Rotor - $34
• KX125 KX250 KX250F (04) Stock Bottom Triple Clamp - $30
• New KX250F (04-05) Owner’s Manual - $20
• New KX250F (04-05) Suzuki RMZ250 (04-06) Acerbis Black Radiator Shrouds - $25
• KX250F (04-05) Stock Green Radiator Shrouds with Stock Graphics - $30
• New KX250F (04-14) OEM Exhaust Valve # 12005-0002 - $55
• KX250F (09-16) Stock Shifter - $15
• New KX250 (88-07) OEM Piston Needle Bearing # 13033-1010 – $12
• New KX250 (92-07) OEM Clutch Spring Kit # 92144-1351 - $30
• KX250 (03) Micro-K Parts Catalog - $15
• New KX250 (05-07) OEM Piston Kit - $70
• New KX450F (06-11) OEM Clutch Spring Kit # 92145-0370 - $27
• Parts removed from a 2012 KX250F:
o Motor Mounts - $22
o KX250F (11-16) Header Pipe - $80
o KX250F (09-16) Muffler - $90
o Shock (09-16) - $150
o Linkage w/ Bolts - $60
o KX250F (11-12) Triple Clamps, Top and Bottom w/ Bar Mounts - $120
o KX250F KX450F (09-16) Front Wheel Complete - $150
o Electrical Wiring Harness - $50
o Throttle Body - $100
o Throttle Cable w/ Housing - $15
o Cam Shafts Intake and Exhaust - $150
o KX250F (10-16) Oil Pump Assembly, Gears, Screens, etc - $50
o Transmission, Shift Forks, Shift Drum, Primary Drive Gear - $190
o Shift Shaft and Shifting Assembly - $40
o KX250F (09-12) Inner Clutch Cover Case, Clutch Cover, and Water Pump - $70
o KX250F (09-15) Case Saver - $9
o KX250F (10-14) Complete Clutch Kit; Basket, Inner Hub, Pressure Plate, Fibers, Discs, Springs, Push Rod, Washers, Nut, Bearing - $150
o KX250F (06-18) KX450F (06-18) Rear Brake Caliper - $55
o KX250F (09-12) Stock Plastic Kit: Front Fender, Front Number Plate, Side Panels, Radiator Shrouds , Fork Guards - $70
o KX250F (10-16) Straight Non-Fill Side Radiator - $70
o KX250F (09-16) Stock Radiator Hoses, Clamps, and Fittings - $22
Suzuki
• New RM125 RM250 (01-08) Clutch Cable; Part #58210-37F11 - $19
• RMZ250 (07-16) RMZ450 (05-16) Stock Case Saver - $12
• RMZ250 (07-16) Cylinder Mount Bolts - $10
• RMZ250 (07-17) OEM Clutch Pressure Plate - $10
• RMZ250 (10-13) Clutch Actuator Arm - $20
• RMZ450 (08-14) Stock Clutch Basket - $80
• RMZ450 (08-15) Stock Clutch Pressure Plate - $20
• RMZ450 (2012+) ODI Yellow Emig Grips - $12
Yamaha
• YZ450F (10-13) FMF JGR Ti Header & Factory 4.1 Muffler, used for two motos by #33 - $800
• Pro Taper Stock Handlebars - $40
• YZ YZF (06-14) Stock Bottom Triple Clamp - $40
• New YZ80 (81-01) YZ85 (02-18) OEM Crank Bearing #93306-20468 - $10
• YZ80 YZ85 (93-14) Fly Wheel Cover - $15
• YZ80 YZ85 (93-17) Front Axle - $17
• YZ80 YZ85 (95-17) Stock Pressure Plate - $10
• YZ85 (02-17) Shift Forks, Pins, & Drum - $30
• YZ85 (02-17) Stock Exhaust Pipe - $70
• YZ85 (02-17) Ignition Coil Assy - $25
• YZ85 (02-17) Rear Brake Master Cylinder - $25
• YZ85 (02-17) Rear Brake Caliper - $45
• YZ85 (02-17) Rear Brake Pedal - $24
• YZ85 Supermini Cylinder, Piston, Stroker Crank
• New YZ125/YZ250 (93-17) YZ250F (01-13) YZ450F (03-09) UNI Air Filter - $25
• YZ YZF (2005) Stock Top Triple Clamp - $30
• YZ125 YZ250 (02-18) YZ250F YZ450F (02-08) Ride Engineering Blue Axle Blocks - $15
• YZ YZF (04-18) Stock Titanium Pegs off 2013 YZ250 - $40
• YZ YZF (06-07) Front Brake Hose Clamp - $10
• YZ250F (03-05) Stock Muffler - $70
• YZ250F (05) Stock Upper and Lower Triple Clamps - $50
• YZ250F (06-07) Complete OEM Clutch; Basket, Inner Hub, Pressure Plate, Springs, Discs, and Plates - $80
• YZ250F (06-09) SDG Step Bump Complete Seat - $40
• YZ250F (06-09) Shift Shaft and Shifting Assembly - $40
• YZ250F (06-09) Motor Mounts w/ Bolts - $25
• YZ250F (06-09) Carbon Fiber Right Side Engine Guard - $35
• YZ250F (06-13) Stock Cam Chain Tensioner - $17
• YZ250F (07-08) Complete Transmission - $100
• YZ250F (07-09) Left Side Motor Crankcase - $100
• YZ250F (07-09) Kick Start Lever - $55
• YZ250F (2008) Frame - $130
• YZ250F (08-09) Stock Triple Clamps w/ Bar Mounts - $100
• YZ250F YZ450F (Off an 08) Linkage Arm w/ Cerakoted Link Relay - $100
• New YZ250F (07-13) Moose Racing Case Saver Guard - $25
• New YZ250F (10-13) OEM Radiator Hoses and Clamps - $24
• New YZ250F YZ450F (14-17) Case Saver Chain Guard - $9
• YZ250F (14-17) YZ450F (10-17) Stock Linkage Arm - $50
• New YZ250F YZ450F (02-16) OEM Throttle Housing & Tube - $30
• YZ250 (99-18) Stock Clutch Cover - $40
• New YZ450F (06-09) OEM Radiator Hoses and Clamps - $24
• New YZ450F (10-17) OEM Clutch Cover Gasket 33D-15453-00 - $10
• YZ450F (10-13) Stock Header Pipe - $40
• YZ450F 2014 Owner’s Manual - $30
• YZ450F (14-17) Stock Head Pipe - $100
• YZ450F (14-17) OEM Clutch Cable - $15
• Plastics for YZ125 YZ250 (02-14):
o Cycra Blue Front Number Plate - $10
o 3 Sets Of White Fork Guards - $10 per set
o 5 Sets Of Blue Radiator Shrouds - $20 per set
o 4 Sets Of White Side Panels - $20 per set
o 2 Blue Rear Fenders - $10 ea
o 2 White Rear Fenders - $10 ea
Other
• Dunlop MX52 Front Tire 80/100-21, Nearly New - $55
• New Renthal Ren Checkered Pad Blue/Silver - $25
• New Renthal Chromed Supercross Bar Pad - $25
• Ogio F9900 Gear Bag Grey - $100
• Ogio 800 Helmet Bag - $30
• New Moose ODI Lock On Grips - $20
• ODI White Emig Grips - $15
• Works Connection Clutch Lever and Red Perch - $40
• Sunline Clutch Perch - $25
• New Shock Sox, 6” Black - $20
Email mjwilcox4490@gmail.com for pictures.
kxpete
Carlsbad, CA, USA
7/5/2017 10:58pm
Pm sent
Hondas4Life3
Spring Hill, KS, USA
7/6/2017 2:04pm
Is that 05-07 kx250 piston kit single or double ring?
7/6/2017 3:41pm
It is a double ring.
n8janis
Huntington Beach, CA, USA
9/15/2017 2:04pm
what bike does the pc pipe fit on?
9/15/2017 6:35pm
Sorry I sold it last week. I updated the listing.
809
Paducah, KY, USA
9/16/2017 6:06am
I want the YZ axle blocks. What condition is the YZ plastic you have?
9/16/2017 11:45am
The plastic is all in good to fair condition. I also have a blue Cycra front number plate (06-14) and a couple sets of white fork guards for 2008 and up bikes but each set has a starting device hole drilled.
Email me mjwilcox4490@gmail.com
Post a reply to: Shop Clean Out - All Makes Parts
