- Pick trends
- Create a private league
- And more!
Edit: I also shimmed the back bolt holes 1/4" to tilt the front tip of the fender upwards.
I just drilled holes in the fender and used washers to lift the front.
Iirc, when i did mine, i elongated the 2 pre-drilled holes in the fender and slid it back so the raised part sat tight on the clamps, measured the distance between the mounting holes on the clamp and drilled 2 new holes in the fender, job done.
Post a reply to: 2002 CR125/2015 CRF Front Fender conversion w/ Cycra Stadium Plate, question.
