RM 125 hub damage repairable?
5/15/2023 10:16pm
Long story short, all but one of my sprocket bolts came loose and one hit the swingarm resulting in elongation of that bolt hole. Is it worth getting it repaired or not?
Factor E
So Cal, CA US
5/16/2023 5:54am
No    junk it    Material is weak now
rmracer289
Camillus, NY US
5/16/2023 10:15am
I wouldn’t. There is a guy in the for sale section selling a set of wheels for an RM125.
NITRODOG
TEMECULA, CA US
5/19/2023 5:20pm
We had an old school machine shop that would drill them out a size bigger, and then press in metal sleeves...we did this several times over the years with no issues.  I'm just not sure there are many old school machinists around though.....
johnk408
Ft Mitchell, KY US
5/29/2023 4:04pm
I have some wheels from 04 rm125. Pm if interested. Would sell just one if needed.
willbilly
Corpus Christi, TX US
6/2/2023 6:49pm
The sprocket bolts will never stay tight when the hub holes oval. Either do what Nitodog suggests or replace. Tusk makes good wheels for a reasonable price.
debun
Charlotte, NC US
6/7/2023 8:22am
sonerson83 wrote:
Long story short, all but one of my sprocket bolts came loose and one hit the swingarm resulting in elongation of that bolt hole. Is it...
No photos provided so speculating on the condition.  The sprocket should transmit  torque through friction so you are fine once you properly tighten the bolts.  You might have better luck tightening the nut rather than the bolt and using a medium strength thread treatment.
debun
Charlotte, NC US
6/9/2023 10:52am
spimx wrote:
Time-sert might actually be stronger plus you will have the tools  https://www.ebay.com/itm/283847647435?hash=item4216a360cb:g:bkYAAOSw-YRgDCkT&amdata=enc%3AAQAIAAAA8JIKHk0J5rAwbrBCBj3UkPzRU69XN%2BsrknpV2ITLepAybpw6St9OUzpuiBxgwsgOlYBJSata73Mm7aIVF72sWAH6b4YDBM6CEVBD9W%2F2VZ7bQ4%2B%2BQ5quRueVZKBZL1mdvVO5qBiZnGW8Y6YNc6WgOENiC6ULw7sVyM2fvCcPrvwFzVM5%2FuwsDnMRylJcqtBuu0IJgYRTdjlujdIHq350pPfQXThSikqyvxZCjhRSVJv9Z8VMK6uv1cMoqYlTOmCrPZq6wsnsv86oL1sx1VlcOpr71Os6Z%2FXreYC00NreBh3EMJZIpQvumHFdWSe9h7KOyA%3D%3D%7Ctkp%3ABk9SR8zj5eySYg
https://www.ebay.com/itm/283847647435?hash=item4216a360cb:g:bkYAAOSw-YR…
But it's a nut and bolt Huh
Post a reply to: RM 125 hub damage repairable?
