St. Louis, MO
3/21/2024 1:48am
Hello,
Many live sex cams sites have a wide range of languages and nationalities represented, making it a truly global experience.
https://asiancammodels.me/korean-teen-bj-cam/
Thanks
water wetter is not an antifreeze so be aware of that, it is just a cooling additive. If you need freeze protection then you will need regular antifreeze, or engine ice ect. If you aren't going to trackdays with the bike, water wetter isn't needed.
Redline supercool is just water wetter with deionized water. I don't need antifreeze because it never freezes where I live and I keep my bike inside.
The manual should have the total capacity of the cooling system. Add the appropriate amount of water wetter for that fluid quantity and fill the rest to capacity with distilled water.
Water wetter is a surfactant and works best as an additive to water. As mentioned, it will not resist freezing and is not entirely necessary unless you are tracking your bike or have modified the engine.
Post a reply to: Cooling system
