Are x ring chains worth paying 160 on? Or is it overrated.
Edited Date/Time:
Totally totally totally worth the reduced maintenance (I adjust my chain MAYBE once a year ... no kidding). I'd pay $500 for an x-ring chain - I am that happy with them ... but luckily they only cost about $105!
I am personally a fan of the DID ERVT X-ring chain with a tensile strength of 8440 lbs. I get the clip-type master links.
*** ALSO: A plug for Ironman sprockets (by Dirt Tricks). Nothing compares. I've owned 10+ of these sets, never worn a rear out (and that's after 100s of hours on each, have replaced 1 front - but it wasn't bad). Pair a set of Ironmans with an x-ring chain and enjoy an extra hour of sleep … EVERY DAY. ***
x2
DID ERVT X-Ring chains with Dirt Tricks Ironman front and rear sprockets.
The longevity is incredible, so much so, that I won't run any other combo.
Do It In The Dirt!
I've had great experience with the Primary Drive X-ring chains from RMATV/MC. Depending on length they run $80 or so.
Definitely agree that X-ring is well worth it. After it stretches in the first couple rides, they almost never need adjusted. The X-ring protects the point of greatest wear, where dirt gets between the pin and roller.
Also +1 on any type of steel-toothed rear sprocket. I've been using the Supersprox steel/aluminum composite, but Renthal Twin-Ring looks good and both Moose and G2 make a sprocket similar to the Supersprox.
And if you don't mind the extra weight you can go with all-steel Supersprox or Vortex for half the price. Those have fairly minimal center spokes to them.
With steel teeth you can go through 3 chains and front sprockets for each rear.
