How does it fit, big small? I wear a small in some brands and medium in others. Still have not found one in any local shops to try so any help would be great.
In our experience the run on the loose side. I typically wear a size large, and I have worn a large Astars, but I also wear a medium in Shoei and I think 6D. I would say go with the smaller size if you are between sizes. If you are a solid medium stick with the medium. But since it sounds like you are between go with a small. There is also some adjustment available with the net thing the Astars has on the top inside the helmet.
Post a reply to: Alpinestars helmet?
