Chester
2899th
10/8/2021 5:04pm
Hi,
I recently purchased a 2016 KTM 350 sxf, the bike seems great but just has one small issue.
The front wheel moves side to side slightly, at first before purchase I figured it was bearings - no biggie.
On inspection it seems as though the spacers aren;t being held in position by the fork legs,
The hub is an aftermarket(orange) hub - I can't see any markings as to a brand unfortunately just a small qr type code which won't scan on my phone.
The spacer on the bike look like oem one and when they clamp in place to hold the axle reducer inside the wheel between the bearings, they aren't wide enough.
I know its a long shot but does anyone have any suggestions of other spacers to try, would like to try and avoid buying a new hub.
Thanks you in advance - will happily send a box of British beer to anyone with a remedy!
Cheers
Cheers
May not be able to help or identify from these, but all I have on my phone, can take more later if needed,
Cheers
Thanks
I had a similar issue with a set of wheels I bought used. After some digging I found out the hub was a Hollis hub and had "360" marked on the Rim, After talking to a few companies I found out that SM Pro spacers will fit the wheel.
Post a reply to: sxf 350 front wheel spacers
