suspension
10/6/2017 6:58 PM
can having low psi in your rear shock spring keep the shock from rebounding all the way?
10/6/2017 7:23 PM
How does one add psi to a shock spring?
Is this some kind of technology I havnt heard of yet?
10/6/2017 7:27 PM
shocks have nitrogen inside of them
10/6/2017 7:31 PM
Ouch. Rekt
2009 Kawasaki KX450F
2009 Kawasaki KX250F
2002 Suzuki GSXR 600
10/6/2017 7:35 PM
Is your shock not extending completely while on the stand? Its not going to fully extend under its own weight. Gunk in the shock, bad shock oil, low nitrogen, or a broken spring or spring retainers are all causes of that. Really if the spring and retainers are in good shape and you have preload on the spring, it should fully extend while on the stand.
10/6/2017 7:38 PM
Acidreamer wrote:
Is your shock not extending completely while on the stand? Its not going to fully extend under its own weight. Gunk in the ...more
it doesn't extend all the way under its own weight (on bike stand) and its too soft to be stock suspension
10/6/2017 7:39 PM
should i just get it fully rebuilt?
10/7/2017 4:59 AM
The spring has nitrogen in it?
Asking for a friend
10/7/2017 8:04 AM
Check your linkage when shock is out of bike.
10/7/2017 9:15 AM
If its just super soft yea id send it in to be repaired. The spring on it should still be stiff enough to extend the swingarm while on the stand.
10/8/2017 6:46 AM
How much preload do you have on the spring? Soft suspension and not coming back all the way up under its own weight point to a spring that's too loose.
If it has the same problem on the stand, I'd first make sure all your swingarm/linkage/shock bearings are well greased and in good shape.
