sss forks on complete sss front end on ktm?
9/4/2017 2:12 PM
Hey guys anyone done this? I have a 16 sxf250 and the 4cs are terrible.
I have a few sets of 06-09 yzf forks, triple clamps, front wheels
12 yz450f front end
Who has put sss forks on a ktm? whats it take? I have all the sss forks clamps and front ends sitting around. Id love to make this work.
9/6/2017 2:12 AM
Have previously fitted the whole SSS forks and still used ktm wheel/brake and also just fitted the inner carts into the 4cs tubes.
The second option is the easiest by far, send me your email and i'll forward you a CAD file of the adapters you need to get made up
9/6/2017 10:56 AM
bowser wrote:
Have previously fitted the whole SSS forks and still used ktm wheel/brake and also just fitted the inner carts into the 4cs ...more
I am looking to do the same, could I have the file please?
weston881@gmail.com
Cheers!
9/6/2017 4:51 PM
I'm on hold till Sunday. Will send the file when I get back. You guys can then find someone local to make them foe you.
Wayne
9/14/2017 2:52 AM
Who else wanted a copy?
9/14/2017 7:20 AM
I do please
9/14/2017 7:39 AM
I would appreciate a copy, my email is leetaylor891@gmail.com
Many thanks, sir!
9/15/2017 1:58 AM
emails sent. If anyone wants a copy you need to either pm me your email or post it here. Absolutely pointless sending me a pm just saying you want a copy without an email address.
9/15/2017 2:35 AM
Recently did this exact conversion
9/15/2017 6:17 AM
AfricaOffroad wrote: Photo
Any tricks on fitting the brembo caliper to the kyb lug?
9/15/2017 6:52 AM
My suspension guy fitted the WP feet and bottoming valves to the KYB's, so everything bolts right up like stock.
In the pic, if you look carefully, you can see a 0.5mm thick spacer in the lower triple clampPhoto
9/15/2017 6:54 AM
9/15/2017 7:28 AM
bowser wrote:
emails sent. If anyone wants a copy you need to either pm me your email or post it here. Absolutely pointless sending me a pm ...more
PM Sent!
9/15/2017 6:39 PM
In the pic, ...more
Sano set up!
That's exactly what I want to do.
Any trick to getting the WP bottoms on the fork leg?
Does that spacer go all the way through, or is it just along the bottom edge of the clamp?
9/15/2017 8:25 PM
stone881 wrote:
Sano set up!
Does that spacer go ...more
They make a kit to go SSS internals for a reasonable price....A lot less work
9/15/2017 10:08 PM
The spacer runs the full depth of the triple clamp. What you see in the pic is just a locating collar to stop the spacer moving when you slide the forks in
9/15/2017 10:11 PM
Regarding WP feet, the thread is compatible with the KYB stancions
9/15/2017 11:53 PM
yes thread is the same.
for a cheaper alternative you can just use 0.2mm stainless/brass shim for the bottom clamp area.
6/25/2019 4:41 PM
bowser, is your offer of the CAD file still open? I'd love to do that on mine; I'm running a Brembo MC with a Nissan caliper...not ideal...
Thanks!
Natester551v@gmail.com
6/25/2019 6:18 PM
I have a machine shop. Could you send me the file please? Red.leaderATyahoo.com
If someone wants me to make them a set, let me know.
3/16/2020 6:29 PM
If someone wants me to make them a set, let me ...more
How much would a set run?
3/16/2020 9:02 PM
Would you be able to send it to me also? Thank you
Tierrabmx@gmail.com
5/25/2021 1:45 AM
please send me that CAD file as well!
5/25/2021 1:46 AM
5/27/2021 9:47 PM
jason@tandsdvbe.com
Please send it here too!
