shock problem
8/22/2017 1:44 PM
Ok I am rebuilding a shock from a 2004 rm250 and when I took it apart it was really hard to separate the body from the shaft assembly so I used a mallet to get it out and thought it was just hard to get out. Then I go to reassemble and no oil will flow through the piston or rebound circuit, so it just pushes oil to the other side of the shock body. I don't know if this is something I can fix or if I need to take it to a shop.
8/22/2017 2:40 PM
Make sure the comp and reb screws are turn out anticlockwise or to soft. You will also probably have to push the reb needle back in the centre of the shaft. Post some pics could be helpful.
