Athens, PA
5/15/2018 7:37pm
well it’s been a few months and bike running great!! endless power no issues with it. until i one race in september it shut down on me 6 miles in. got it home found broken ground wire to the coil. repair it and no spark still took stator flywheel off and tested it blue and white wire no ohms. got with company sent back old stator and got new one it and bike run great again. they said old one burnt (most likely form broken ground wire.)road it hard two sundays in a row then drove 1,333 miles to a race and made it 4 miles and shut off same as before. pulled bike off track and checked no spark?? wtf . got it home and found same thing no ohms and smells burnt. bought bike with no spark and got new stator road it 5-1/2 months no issue till burnt stator in september and again now same way. i’m two stators in they warranted second one. any idea ??
not running hot and temps aren’t much different then in april when i first raced it
Have you checked your engine mounts?
If they become rusty you are still loosing your ground for the stator and electrical system and thus can cause failure just like the broken ground wire.
this is my ground right to frame
By the way that photo shows some work needs to be done to clean the wiring up and weather seal it.
Post a reply to: no spark cr250r
