new top end kick start wont move KXF250 2017
7/30/2021 4:44 AM
I just installed a new top end, cylinder, cams, piston. I put it together and the kick start went half down and then all the way up and will not move any more.
Could it be the cam clearance?
or did i over tighten the cam holder?
7/30/2021 5:04 AM
Piston may be in backwards and valves are hitting the piston
7/30/2021 5:15 AM
two larger circles on the piston are in the back smaller are on the exhaust side.
7/30/2021 6:04 AM
I just went and was able to turn the flywheel nut. I could hear the compression out of the exhaust. like a slow kick start. However the kickstart wont budge.
7/30/2021 6:52 AM
Did you lock the cam chain tensioner before install?
7/30/2021 8:00 AM
Timing off, piston hitting valves. Double check timing marks on crank and cams.
Powerband in every gear !
7/30/2021 12:15 PM
Timing is off
Piston in backwards
Doesnt take much for it to not work. One tooth on the cam chain off and it will touch
Gone:
2006 CRF230F
2008 KTM 200 XC
2017 KTM 250 SX
2019 CRF250R
Current: 2021 YZ250F
7/31/2021 4:18 AM
Make sure the marks on kick start gear aligned/timed were they should be
for full rotation
