NZ
im debating on buying a lectron for my 07 rm125. wanting more peoples import on it? wondering if its worth ut or not?
thanks
thanks
Went back to stock carb. Would not buy another Lectron.
Learning how to jet is like anything else and takes time and practice. But, when you master it or get proficient at it, it's actually relatively painless. Everyone starts out not knowing what to do. Find someone comepetent (someone who's bike doesn't grenade every weekend and runs well) and ask them if they would show you the ropes. Most people who are knowledgeable would be glad to help you learn.
I see a lot of people throw a new carb at a bike when there are underlying issues such as faulty reeds, leaky main seals, excessive piston to cylinder clearance etc which complicates things. They will buy a new carb and still struggle.
Spend an afternoon with someone knowledgable and explore carb setting on your bike. What does lean sound like on a pilot jet? What does too rich or too lean sound like on a needle clip setting? Twist the air screw and see how it affects well into the needle range.
Once you get it right, you'd be amazed at the range of temp and humidity/ elevation the bike will run decently. I would have a winter setting and a summer setting for most of my bikes and an airscrew adjustment would clean things up when needed. Knowledge is power and can save you a lot of money. The Lectron carb is only as good as Lectron's settings derived from their R&D. Final adjustment is still necessary.
When you get the jetting right on a mechanically sound engine, it's a thing of beauty. When you learn how to do it, it's a game changer.
Plus, the lectron is a big chunk of metal that's a pain to fit in the rm125.
Tried jetting the carb and one day it ran perfect, next ran like crap.
Sale came up and i bought one. Runs consistently good whether i ride at sea level or 6000ft+.
I only ride woods, but zero complaints.
Post a reply to: lectron woth it or not?
