leaky shift shaft seal??
9/15/2018 4:16 PM
Any recommendations on how to replace without having to pull shaft out? 89 kx80
"So you're telling me there's a chance!!"
9/15/2018 5:07 PM
The best way is to pull the shaft, but if your are careful you may be able to pry it out with a small screwdriver or a pick.
9/15/2018 6:44 PM
Drill a small hole in the seal and screw a metal screw in and use the screw to pull it out
9/17/2018 10:41 AM
Look at Lisle seal pullers...wait, by that time you could have bought a new clutch gasket and done it right.
Tape up the end of the shaft to TRY to prevent damage to the new seal.
