kx80 Clutch Basket Removal??
7/28/2018 10:46 AM
Trying to take clutch bracket offand cant figure out how to hold the inner hub from moving so I can get the nut to loosen. Any ideas? I can keep gears from moving but not the inner hub Photo
"So you're telling me there's a chance!!"
7/28/2018 10:56 AM
Impact gun will spin that nut off. We made a special tool to stop the basket from spinning, weld about 4 steel clutch plates together, then weld about a foot long handle on it. You can hold the handle to undo the nut.
7/28/2018 11:02 AM
any other thoughts? I'm not a welder...
7/28/2018 11:03 AM
Impact gun?
7/28/2018 11:09 AM
Muscle-Milk-KTM wrote:
Impact gun?
I'll try the impact gun, I thought you meant I needed to do both
7/28/2018 11:11 AM
Edited Date/Time: 7/28/2018 11:12 AM
No sorry I didn't explain very well, if you don't have an impact gun, you can make a tool so you can hold the basket whilst you back off the nut with a wrench.
7/28/2018 12:40 PM
Edited Date/Time: 7/28/2018 12:40 PM
thanks for your help
7/28/2018 12:45 PM
No problem.
8/15/2018 7:25 PM
Edited Date/Time: 8/15/2018 7:31 PM
So I got the engine back in frame and everything almost buttoned up, but my clutch does t seem to engage or disengage. when I pull lever in it stays in..... any thoughts? No rebound...
8/15/2018 8:33 PM
Edited Date/Time: 8/15/2018 11:00 PM
rucka356 wrote:
So I got the engine back in frame and everything almost buttoned up, but my clutch does t seem to engage or disengage. when I ...more
Return spring broken maybe? Clutch push rod?
8/16/2018 7:06 PM
Edited Date/Time: 8/16/2018 7:06 PM
Welp, turns out I was missing the push bearing and other parts.. More parts on order...
