do i need to re-valve my CV's?
groggylbc
Long Beach, CA US
my compression is clicked 4 out....anything after that it sits too low and is too soft. my rebound is 24 out.
im kinda suspension stupid, so whats your opinions. thanks
Benton, LA US
7/2/2017 5:28pm
First check your static and race sag to make sure you have the correct springs on the shock. You can use racetech.com to check your spring rates with their "spring rate calculator" for the forks and the shock. If either one is incorrect it will be very hard to dial in your suspension.
CarlinoJoeVideo
Portland/Los Angeles, CA US
2361st
7/2/2017 6:44pm
Cone valves have a preload adjuster on the top. I run my 1.5-2turns in from full out. Each 1/2 you will feel a click. This should help. If not your spring rate might be not correct.
bowser
7/3/2017 2:30pm
Sounds like your spring rate is too low.
Do you know if the CV's have MX or Enduro valving? you can buy them with either and the later is a lot softer
groggylbc
Long Beach, CA US
7/3/2017 3:57pm
bowser wrote:
Sounds like your spring rate is too low. Do you know if the CV's have MX or Enduro valving? you can buy them with either and...
My friend races pro in Europe... I got the really cheap from his suspension guy.
He asked what style I rode/raced
(MX/grand prix off-road). Maybe he just got it a little wrong
bowser
7/3/2017 4:57pm
try to find out spring and valving details, hard to advise otherwise without this information
CrGuy2T
Santa Fe, TX US
3719th
7/7/2017 8:47pm
If you bought them used, the answer is yes. So many people buy used suspension and never get it set
Up for themselves.
Post a reply to: do i need to re-valve my CV's?
