LAGONISI
GR
I need for cr250 2002 with keihin 38mm from yz250 2017 the best carb setting
sea lever normal engine only scalvini exhaust system
Make sure that the power jet, the jet or jet hole itself is plugged, The TPS does not need to be used if you don’t want to hook it up.
The powerjet circuit advice is good.
Keihin black to Mikuni green
Keihin Yellow to Mikuni yellow/black
Keihin blue to Mikuni yellow/ red
Connectors: https://easternbeaver.com/Main/Elec__Products/Connectors/Sealed/SM-HM/s…
Make sure the power jet passage way is blocked, as you will not be using the power jet on the CR.
Make sure that you do have a carb from 99' KX250, as that was one of the few years that came with a #7 slide. Most of the other years KX250's came with a #8 slide, which would require slightly different jetting specs, or the use of a different slide.
pilot--42
main--170
Air screw---1.5
This is assuming you are using an 02'--07' engine, and the carb is using a #7 slide in 60f--90f weather
https://www.procircuit.com/jettingspecs3.htm
Post a reply to: cr250 2002 keihin carb setting
