cr125 water pump/clutch cover help 1985/1986
6/15/2017 1:05 PM
Gday,
I'm restoring a 1985 cr125. Like many others my clutch cover was corroded beyond repair and I did get a 1986 replacement but would really like some input on what i found next.
The 1985 cr125 cover I have has 600 stamped on it, the 1986 one is slightly wider and has 700 stamped on it. This added width means the 1985 water pump shaft does not quite fit right. It's very hard to find information on exactly this point, there's plenty around about repairing covers and what not, but I can't find reference anywhere to the changes in the water pump shaft.
My measuring was done poorly sorry, but the 1985 shaft is 75mm in length, I expect the 1986 is about 3-5mm longer.
The 1986 shaft is the one with the plastic insert/ramps, the 1985 is the one without. This checks out on the honda parts manuals.
My issue is I need to find someone with knowledge of this and am trying very hard to find a 1986 cr125 shaft to physically measure and see if it fits. If anyone has any ideas of somewhere wrecking a 1986 that I can buy this part from please let me know!
Anyone with any info on this topic I'd love to hear from you. Sorry for all the pictures, I hope this thread can be of use for people in the future so I've included as much info/pics as I can.
Thanks a heap,
Bogrolls
My 1985 water pump shaft
My 1985 water pump shaft parts
Honda microfische diagram showing 1985 and 1986 difference. All other parts are the same.
My 1985 clutch cover, notice depth/length of posts
The clymer manual page
1986 cover depth
1986 cover
1985 cover
6/18/2017 12:12 AM
Looks like you have one of Russells alloy covers yeah? He must have used the 86 cover to copy for 84-6, I can check my 85 shaft & let you know what I find, when I done the original fitment a couple of years back I dunno if my bike had a 85 or 86 cover as I had 2 or 3 different ones, whichever one I had it fitted perfect when I swapped
the shaft from old to new, I am in Vic give me a call in a couple of days if you like & we can have a chat 0418 274861 Chris
6/18/2017 3:44 PM
Gday Chris,
Thanks so much for taking the time to respond. I'm very keen to make sure an 86 shaft will do the trick, i've been trying hard to find one to buy but haven't had any luck so far.
I'll watch this thread and give you a buzz in a couple of days as you've said.
Cheers,
Mat
6/18/2017 5:39 PM
Cool mate, I just remembered a small issue I had with my alloy cover, the 2 towers that hold the ATAC spring assy where not machined down far enough, my water pump gear was not turning as the teeth where hitting them, I used a die grinder & took the machining down further, I told Russell about it & he said he would check & re machine them deeper, Looks to me like yours is not done, Is that your problem?
6/18/2017 7:57 PM
Interesting, the issue is as you say the gear does grind on the 2 towers for sure. I figured that was happening because I had the gear/shaft and that the spacing on the 86 shaft was different to what I had. Even if those posts were flat I think i'd have issues with the shaft being too short.
Have your posts been grinded right the way to the bearing face ?
I think these 3 are what the 1986 one looks like, looking at the outside face of the gear how it's not perfectly flat i figured it must sit away from the cover a little bit unlike the 1985. I don't know if you remember but is this what yours looked like ?
6/20/2017 2:18 AM
Edited Date/Time: 6/20/2017 1:36 PM
Well after searching everywhere I was lucky enough to snag one that just came up on ebay, bought it as soon as I saw it.
I'll write back when I receive it and hopefully that's the issue solved. Full steam ahead on the restore now I'd say.
http://www.ebay.com.au/itm/Honda-CR125-Water-Pump-Shaft-1986-Used-Part-P-N-19240-KS6-000/322559320595?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
3/13/2019 5:13 AM
I’m in the exact same situation. I’m restoring a 85 CR125 and bought a cover from Russel that is 700 cm. I’m I nterestd to see if the 86 water pump worked.
3/14/2019 1:21 PM
Gday Matt,
Would you believe i'm still working on the bike. I went ahead and purchased the 86 gear and it fits the cover but i have not yet assembled that part of the engine so i can't say for sure that it'll be 100%.
This weekend I can send you pics of the 86 water pump and anything else you're interested in. I'd like to keep in touch with someone else restoring this exact model bike.
Here's what i've done lately, pressed all new swing arm, linkage, steering stem bearings and actually started slowly reassembling. My shock is being rebuilt which is due back on the 27th.
Cheers.
3/14/2019 4:46 PM
Looking good, I have got side tracked with my 85 CR125 too, I have brought a 84 & then some Mugen parts to go on it so it's been moved up in the line but am racing my 74 CR125 & 79 CR250 at the moment so they are taking up time/Dollars.
3/14/2019 5:59 PM
Hey, thanks for the response. The Paint looks great. I just finished tearing mine down. I paid $100 for the bike. It was pretty toast. I’ve had to order lots of parts. So no savings. I’ll definitely have more into it than it’s worth. I hoped to be racing this summer, but this is taking longer than anticipated. Finding parts for a 40 year bike is time consuming. This is my first full restoration and will be a challenge.
I ordered an 86 shaft after talking with a parts guy who has helped a few guys in the same situation. I’ll upload some pictures of my progress tomorrow.
