Byron Center, MI
4/22/2021 7:44am
was at my first area qualifier of the year in like 6th and clutch went out, already got clutch plates and springs ordered because I didn't have any on hand at the time, not sure if I should have ordered a basket and hub. Haven't tore it down at all yet and don't know much about how the clutch works and if it goes out do I throw in just new plates or is there any case I'd need a whole basket and hub, bike wont move just revs out. I have another qualifier soon and need to figure out if I need to order a basket and hub and overnight them.
Make sure to soak the new discs in oil before install, count the exact number of fiber and friction plates, and check your manual for proper spring torque.
If you're still running the stock clutch springs, Pro Circuit makes a stiffer set, greatly helps with clutch feel and not ragging on it as much.
Post a reply to: clutch went out in my supermini(no grinding noise just revs out without moving)
