Yzf 250 19 High compression piston
12/11/2018 11:46 PM
Can it run on pump gas with 14.5:1? Which pipe gives the Best power? I Think about a Bills pipe or akaprovic
12/12/2018 3:24 AM
Edited Date/Time: 12/12/2018 3:25 AM
Youll need at least 93 octane gas. Some bikes with HC pistons will run on it just fine and some wont. Try it and see.
About the pipe, i want to think FMF makes the most power. Double check that tho.
Also youll gain more power with a remap than with those two mods. Consider that.
12/12/2018 5:57 PM
My 19 will not run on 93 here in Florida, USA. It detonates like crazy. Switched to recommended fuel, VP U4.4, and it is a monster of a motor now.
12/12/2018 7:58 PM
Rocket Exhaust makes really good exhaust systems and can build them for custom builds and set ups. Check them out. Good prices too.
12/12/2018 9:38 PM
How High compression? smile
12/13/2018 1:42 PM
when you say remap you mean with the GYTR tuner? I was thinking about getting one but was told i should get an AM exhaust first. Or do you think i would benefit from a tuner.
12/13/2018 4:48 PM
I am running a 14.5:1 piston. Stock is 13.8:1. I am running U4.4 when above 85 degrees and MR12 below 85 degrees.
12/13/2018 4:49 PM
The 2019 does not need the GYTR tuner, it is app enabled.
12/13/2018 9:52 PM
How much more work to the engine? And have you try it on a dyno?
12/14/2018 2:12 AM
A dyno would give anyone the best results. Sending your ecu off to get done by tokyo mods is 2nd best. Trial and error on your tuner app is also feasible. Ill bet theres a bank of maps developing online somewhere. That app thing is cool as hell.
12/14/2018 5:47 AM
It is a full motor.
High comp piston
GYTR head and cams
Carrillo Rod (balanced)
Polished, back cut and blued trans
Ceramic bearings throughout
Rad hoses, enlarged radiators
Full FMF Ti exhaust
12/14/2018 5:51 AM
GoYamaha wrote:
It is a full motor.
High comp piston
GYTR head and cams
Full FMF Ti exhaust
Sounds like a fast yzf tongue
12/14/2018 9:51 AM
No clue yet, can’t ride until Feb/March due to injury so I won’t know until then unfortunately. This was a “dream build” for me. Never done this much to a motor until now.
12/14/2018 11:42 AM
Any one know if big bore kits are available yet?
