Yzf 2008 fork problems. Need help!
11/11/2018 2:06 PM
So I'm taking apart my friends suspension to replace seals and bushings. And while taking apart I notice one of the piston rods is sucked in. It won't retract out. So I take the inner chamber apart and find the plastic is broken. I'm wondering should I replace just the plastic and seals. I've never seen this and am curious how it even happens? Both of them are like this. Photo
11/11/2018 2:07 PM
Better picture if the second Photo
11/11/2018 2:32 PM
If you replace them with the original plastic ones, drill 2 holes 180 degrees apart to prevent pressure build up in the future. I personally would replace with aftermarket aluminium ones.
www.mx-parts.com
11/11/2018 5:32 PM
Buy the zeta aluminum piston. 60 bucks for 2
11/11/2018 8:11 PM
Awesome thank you I will check it out!
11/13/2018 12:46 AM
x2.... as mentioned above, stock ones build up pressure and crack. This is very common
