Phoenix, AZ
I got the wider and lower oem yz450 foot pegs to put on my aluminum frame yz250 2t. I am using the stock 250 foot peg brackets. The right side sits flat but the left side is angled back and up.
My question is do I need the 450 mounting brackets as well to make the pegs sit flat or do I need to take a little off the peg to get it to sit flat?
Thanks in advance,
Jordon
Thanks in advance,
Jordon
The biggest thing you need to look out for is the right side. The peg will go up and hit the rear brake pedal on the radius of the bolt that holds it in. It will groove the pedal and go into the bolt holding it, possibly locking up your break. I have had to file down both old 07 and my 19 brake pedals. If you ride single track or drop your bike, always check it. The first time I found this out...it locked up to me coming down a hill.
Hope this helps.
Post a reply to: Yz450 pegs on yz250 2t
